Injector Misfire P0308 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-27-2013, 01:49 PM Thread Starter
jtaylor75's Avatar
I was pulled a few codes from my 06 6.0 powerstroke.
P0300 random injector misfire
P0308 Injector 8 misfire
Injector contribution codes for a cylinder. I can't seem to pin it down, every time i reset either cylinder 7 or 6 comes backs sometimes neither.
I have an autoenginuity to use, I see that the CKP and CMP goes in and out of sync alot. Does this have anything to do with it.
The truck fires right off whether its hot or cold. When its cold i can see white some coming out of the tail pipe that smells like diesel, which dosnt mean much because I have a cracked head thats leaking diesel into the coolant. When the truck warms up the smoke and the buck goes away. She seems to still run like a bat out of hell. It just has a slight miss at idle plus these codes. Any ideas?
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #2 of 5 Old 02-27-2013, 01:51 PM Thread Starter
jtaylor75's Avatar
Ive also checked the FICM volts and they are right where they need to be. New oil and new motorcraft filters.
06 CCSB FX4 Lariat
Next:
A fuel system
post #3 of 5 Old 02-27-2013, 02:06 PM
Conservative and Proud
Banshee34's Avatar
Quoted: 8 Post(s)
2001 F350, Lariat SC LB 4X4 PSD
Quadzilla Commander
Zoodad with Stealth Screen
The Org. Staff reserves the right to move, modify, delete or merge posts at our discretion and without explanation.
Banshee34 is offline
post #4 of 5 Old 02-27-2013, 04:20 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
The cracked head could easily cause this problem. Fix it before it really costs you money!
Run a check on the CKP, more than likely a bad or dirty connection. CMP as well, it could be either. It is intermittent so it runs. They usually are both needed, but once running it is possible for the CMP to use stored position data. If the CKP goes, it will quit.
You have an AE, use it! Do a contribution balance to find the cylinder. You may have do a compression test as well on the low cylinder.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #5 of 5 Old 02-27-2013, 05:43 PM Thread Starter
jtaylor75's Avatar
i replaced the number 8 injector and it got rid of the P0308 misfire code. But the P0300 random cylinder misfire code is still there. Now i got a code for P0336 Crankshaft Position Sensor A Circuit Performance/Range, so now it seems like i need a crankshaft sensor as well? Im working on getting the cracked head fixed. Hopefully my tax return gets here this week so i can buy a new head.
06 CCSB FX4 Lariat
Next:
A fuel system
