best way to install clamp? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 02-25-2013, 07:47 AM Thread Starter
dpmac83's Avatar
I am trying to get the clamp on the y-pipe to turbo connected and not leaking and was wondeing if anyone had any helpful tips. It is driving me
dpmac83 is offline
post #2 of 13 Old 02-25-2013, 07:49 AM
ADMIN AND TECH
SCUFFY828's Avatar
sometimes they can be a azz , loosen the four bolts at the manifolds and it will make it easier , connect the y-pipe and then retighten bolts at manifolds , that alot of times helps
ITS STOCK
SCUFFY828 is offline
post #3 of 13 Old 02-25-2013, 08:28 AM
Quoted: 2 Post(s)
I remember when I did my egr delete, I had to loosen the turbo bolts to move things around a bit before it would line up.
---Garret
2006 F250 6.0 XLT FX4 CCSB
S&B Intake
MBRP 4" straight pipe with 5" tip
Studded and deleted
CTS w/EGT
Atlas 40 and Looney Tuned
2002 F250 7.3 XL Reg Cab 2wd Sold!
1995 Ram 3500 Dually Reg cab 5.9 12v auto 2wd
Fordtrucktexan is offline
post #4 of 13 Old 02-25-2013, 08:44 AM
Korx's Avatar
I loosened the manifold bolts all the way so that the nut was threaded just enough to hang on. Worked fine for me.
2004 6.0L F-250 XLT - ECSB
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
1995 7.3L 5-Speed F-350 XL Dump
Stock
Korx is offline
post #5 of 13 Old 02-25-2013, 08:58 AM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
i jostled around my turbo until i got it back into exactly the same position it was originally in before the EGR delete.. got lucky i guess
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #6 of 13 Old 02-25-2013, 09:23 AM
All of the mentioned methods work. The thing to remember is the flange faces have to be aligned correctly, you can't draw the connections together with the clamp, it just don't work.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #7 of 13 Old 02-25-2013, 10:36 AM
squawfish's Avatar
FYI... I picked up a new clamp for this connection over the weekend. It appears that Ford has gone to stainless steel vs the copper looking clamps they use to help seal thee connections.
There a PITA..................I had to wrangle the EGR clamp.. it took 3 hours to get it right.
squawfish is offline
post #8 of 13 Old 02-25-2013, 10:38 AM Thread Starter
dpmac83's Avatar
Danny boy, I found that out the hard way yesterday, i had everything all back together and heard the leak so i was trying to jostle everything arount to get the pipes to seat and my clamp broke, Ford got me for about 40$ and now i gotta go home and try it all again. I will try all the the above methods until i get one thast works. thanks all for the info, if anyone else has any other suggestions i would love to hear them.
dpmac83 is offline
post #9 of 13 Old 02-25-2013, 12:17 PM Thread Starter
dpmac83's Avatar
It has been extremely frustrating for me because I just had the trans out to get to the rear engine cover and the topside of the engine torn apart to do the HPOP STC, HPOP replacement. I got it all back together and started up, drove it around the block and heard the leak, went to adjust the clamp/pipes and the clamp broke. So here I am with my truck all back together and cant drive it.
Hopefully it will cooperate with me tonight so i can give my wife her car back!
dpmac83 is offline
post #10 of 13 Old 02-25-2013, 12:49 PM
04cr450's Avatar
Wow, sorry you are having that much issues with this process.... Onky thing I can tell you is that was menttioned before, leave all bolts loose, take the clamp OFF of the y-pipe(you can bend the clamp making it bigger to get off the pipe), then mate the turbo with the y-pipe and hold it there with your hand or by a tie-down strap, then take your clamp and pipe it on around the joint.. This is how I have done it multiple times and never had a leak yet knock on wood... Once you tighten the clamp down- let go of te mate connection and tighten the rest of the nuts and bolts on exhaust, etc... Try that and let us know. good luck
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
