2003 oil supply tube o-ring - Ford Powerstroke Diesel Forum
Old 02-24-2013, 06:44 PM
So I'm putting the truck together from doing head gaskets and decided to check the braided supply tube from the stand pipe to the high pressure oil rail. I found one of the o-rings inside the pipe was pretty much garbage and needs to be replaced.
Does anyone know if I can put just a regular o-ring inside the braided pipe or does it need to be something special?
Old 02-25-2013, 02:39 AM
I believe it will be a metric o-ring since everything else is metric.
Old 02-25-2013, 05:17 PM
Re: 2003 oil supply tube o-ring
I would not play russian roulette with "an o ring that might work". Turbos are expensive.
Sent from my phone that somebody didn't help me get.
Old 02-26-2013, 08:23 PM
[QUOTE=southend;4204106]I would not play russian roulette with "an o ring that might work". Turbos are expensive.[QUOTE]
Not turbo...its from the Stand Pipe to the High Pressure Oil rail under the valve covers. Its a early build 03.
Old 02-26-2013, 08:39 PM
Oh, gotcha. Missed that, but still the same, I don't think you can match the durometer(hardness/softness) specs to prevent premature failure. Thats a failure that could leave you sitting on side the road.
