Sensor Trouble!!!!
Got an 04 6.0 and I found a sensor broke while looking around under the hood.. And i have no idea what it could be. If standing in front on the truck it's on the driver side almost underneath we're the fuel filter goes under the hood .. I uploaded a picture on here don't one it it worked or not but its the sensor.. Hopefully someone can help me out
Lookes like EBP sensor exhaust back pressure sensor
Yes, that is the EBP sensor on MYs 03-04. It is a 50psi 3-wire, 5v sensor, 1/8" npt fitting. The later model year EBPs are different, they use a JIC fitting.
The truck is idleing high and a light miss in it .. The I found the sensor but the engine light or any thing is on?????
That sensor should be mounted to a bracket that is bolted to the thermostat housing or the front of the drivers side valve cover.
The sensor in the picture below is used in a different location. However, it is the same dimensions as your broken sensor. This is what it is suppose to look like.
