No start and white smoke... - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-24-2013, 12:12 PM Thread Starter
Woke up this morning and went out to start the truck... it didn't. I have been researching for about an hour now and have found many possibilites as to what is wrong. When cranking, white smoke is coming out of the exhaust and it smells (to me) like diesel. Also, you can hear a noticeable change in tone of the starter (like losing power) while cranking. I tried to start 3 times and stopped as to not further damage anything. I'm away from home and without tools so I'll probably end up getting it towed today or tomorrow... I'm leaning towards FICM (I hope) but I just don't know. It ran fine yesterday. Coolant and oil levels are fine... Any insight?
Thanks, Ronin
Ronin114 is offline
post #2 of 4 Old 02-24-2013, 01:14 PM Thread Starter
Just went out and it started right up... There is still some white smoke exiting the exhaust. Let it run for a few and it idled pretty smooth. To drive home or not...
Ronin114 is offline
post #3 of 4 Old 02-24-2013, 04:25 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
The white smoke was fuel. So we know your ICP may have been good for a start and the FICM was possibly good as well. I say that, because you need both the FICM and HPO to deliver fuel to the cylinder. However, a misfiring FICM could allow fuel through without operating well enough to start. Stiction could also cause fa similar problem. However, it could have just been the glow-plugs not working and it was cold out!
The white smoke should only last a minute or 2, unless you have a bigger problem.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 4 Old 02-24-2013, 04:32 PM Thread Starter
Hmm. I'm still getting a whitish haze at idle. Didn't notice any irregularities on the drive home. I'll probably go through the whole thing this week... hopefully is starts tomorrow for work.
Ronin114 is offline
Tags
6.0 , egr , ficm , headgasket , problem
