05 6.0 hpo issues - Ford Powerstroke Diesel Forum
Old 02-23-2013, 02:02 PM
Exclamation 05 6.0 hpo issues
First off hello to all as I am new here. I have a 05 f250 6.0 4x4 with just over 180k on the clock. About a year and a half ago I had the studs ,gaskets, egr, dummy plugs, stand pipes and the stc done. Well over the past few months I have had a long cold start now it has had two hot no starts until cool. Edge insight shows icp building slow at start up ficm is 48-48.5 constantly and batts are showing good. Fresh oil and filters as well as fuel filters about 700 mi on both. I pressure tested through the icp and commanded the ipr and the air changed but not much on either valve cover. Changed more on the drivers side than the pass. Just wondering if any one had any suggestions that would help my investigation before I tear this thing apart. Who ever is gracious enough to reply your help will be extremely appreciated. Thanks in advance
Old 02-23-2013, 02:18 PM
Powerstroke Techie
Feedback Score: 3 reviews
If it's your original IPR that would be a good place to start. Like anything else they do go bad
Old 02-23-2013, 02:36 PM
Yes it is the original one. Another thing I forgot to add is they put new orings on the oil side of the injectors also. The first time it wouldn't start hot I pulled the valve covers off and checked the d- plugs and stand pipes and all looked good.
Old 02-23-2013, 03:11 PM
One other thing I didn't mention is that yesterday day I had a local guy hook it up to what he called the same scan software ford has. It showed ipr was ok and while running icp was ok but the truck was tuned at the time if that will change parameters any I forgot to tell him it was not on the stock file. But like I said there was no real change with the air test when he commanded the ipr to 100%.
Old 02-23-2013, 03:22 PM
Powerstroke Techie
Do you remember your exact ICP when the truck was a no start hot? Basically if it was a leak, you would think it wouldn't be so intermittent
It would be worth actually removing and taking a look at your IPR. I have seen broken screens that were intermittent no starts
Old 02-23-2013, 03:28 PM
It was on my edge so it was jumping but it stayed at zero for the first few seconds. Even now if I go to crank after sitting all day it will stay at zero for a few seconds then build up and have an extended crank time.
Old 03-16-2013, 04:11 PM
This is to sinner6.0l i want to thank you for pointing me in the right direction. I have not had time lately to work on the truck or get on here. Today I got a chance to pull the IPR valve and I had a blown oring on the pump side. So far all is good but I have not had a chance to get it good and hot and she what she does. But I know there are always a bunch of dead threads with no out comes so this is the purpose for this post and to express my thanks.
