Good Ford F250 6.0 mechanic - Ford Powerstroke Diesel Forum
Old 02-22-2013, 04:53 AM
Hello just wandering if any one know's of a good mechanic to work on Ford F250 6.0 in the Hamilton, Burlington area? I live in Beamsville,Ontario.
Also my truck right now is at Ford getting the oil cooler fixed and wonder should i install a coolant filter after the oil cooler is changed. will this help the oil cooler from cloging up? Also Will ford install coolant filters ?
Thanks
Brad
Old 02-22-2013, 06:03 AM
Don't waste money coolant filters are a easy install shouldn't take ling with some simple hand tools.
Old 02-22-2013, 07:03 AM
So it is good too install a coolant filter?
Old 02-22-2013, 07:30 AM
Yes!! Definitely
Sent from AutoGuide.com App
Old 02-22-2013, 07:50 AM
Originally Posted by doubledrop View Post
Yes!! Definitely
Thanks When the coolant filter kit is put on do you need to drain the coolant ?
