Stumped on headgaskets - Ford Powerstroke Diesel Forum
Old 02-20-2013, 12:28 PM
Hey guys, I need advice and/or help, my truck has been running great, still is. It's been a while since I've had any issues.
Problem(s) I've been having are slight puking out of the degas bottle on a hard WOT run (has done this for the 2 years I've owned it), but it has seemed to settle itself as of lately.
I've had a slight notion that my head gaskets are going south...I've developed a hiss that seems to be hitting the firewall on the passenger side about glove box level and we can't figure out what it is. In addition to that, I put a new degas bottle cap on, tested it and it held 16 lbs, we put a pressure tester on the degas bottle and it held 10 pounds, when I would power brake it, the gauge climbed up to about 13. We also tested from 0 psi in the cooling system...at 17 psi boost on a brake torque it went to 3 psi coolant pressure.
Are my hg's going south?? Always starts great, no miss...runs right at 190 degrees ECT, and OT. Never gets hot while towing, I have awesome deltas,...etc....any ideas on where to go from here?
Old 02-20-2013, 02:02 PM
Headgaskets are on their way out. Probably aren't too bad yet but if its puking p
Out of the degas bottle and you changed the cap and the egr is gone then that's your problem. Mine did the same thing before I studded it. One night I was beating on it pretty hard and it puked out all over the battery and fender liner. I drove it for a few weeks after that and it never did it again but I didn't beat on it either. When I had the cab off and studded it the gaskets were blown. Not bad like some I have come in the shop but they were blown.
Old 02-20-2013, 02:05 PM
Oh and the hissing noise.... Did you look at the bellow on the passenger side up pipe? Had one the other day that didn't look broke but when I pulled the up pipes out it fell in 2 pieces!
Old 02-21-2013, 09:41 AM
Re: Stumped on headgaskets
Sounds like your gaskets are gone. You shouldn't build pressure that quick. It's all a matter of how fast the needle moves at a WOT run.
Old 02-23-2013, 12:03 PM
Winning DUHHH
Visually looked and no signs of soot.
Sent from AutoGuide.com App
Old 02-23-2013, 12:04 PM
Winning DUHHH
I will build a setup to watch it at WOT
Old 02-23-2013, 01:18 PM
could the hissing noise just be the turbo??????????????????
Old 02-23-2013, 01:58 PM
Winning DUHHH
Really lol...vagina or not, hard to be that ignorant!
Old 02-23-2013, 04:57 PM
I'd knew my connotations of sarcasm would be taken seriously on the 'org
Old 02-24-2013, 01:13 AM
Winning DUHHH
Can't see post count or signature on mobile, hard to weed out the sarcasm
