vacuum pump - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-17-2013, 09:25 PM Thread Starter
vacuum pump
Hi I have a 2004 f350 6.0 with 95k and my vacuum pump runs constant when the truck is running and if i unplug the hose going to the vacuum reservoir and plug it with my finger it still doesnt shut off. does this mean my vacuum pump is bad?
keith12088 is offline
post #2 of 6 Old 02-18-2013, 08:06 AM Thread Starter
can anyone help?
post #3 of 6 Old 02-18-2013, 08:12 AM
Assuming you are plugging the pump side (not the reservoir side ), then I would think you have a bad pump. Have you put a vacuum gauge on it?
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #4 of 6 Old 02-18-2013, 08:13 AM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
Seems like there is a sensor to monitor the vacuum that needs to be looked at . Can 't tell you where it is though, should be in the line or vac canister near the pump.
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #5 of 6 Old 02-18-2013, 08:18 AM
ZMANN's Avatar
Quoted: 1477 Post(s)
I think the pump stops with an internal switch
EDIT looks like it is internally switched on and off and you can open it up and see if it's damaged
but it also might not be achieving the proper vacuum and that's why it doesn't shut off
We Miss you Ronnie
ZMANN is offline
post #6 of 6 Old 02-18-2013, 08:48 AM Thread Starter
I have not put a gauge on it. i just noticed that it really loud i can hear it in the cab of the truck with the motor running and the ac on. it does not sound very good. kinda sounds like something is rattling inside the sump. i just wanted to make sure there was nothing else before i replaced it. thanks
