- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
When you order or go buy wheel bearing assembly you get the wheelbearing unit. Which is around 340 dollars each depending on where you go. When you order or go buy a hub assembly you get just that the hub assembly. Wether you get aftermarket hubs from warn, mile marker, super winch, or some other company. Or if you go the dealer and buy the factory hub assembly that allows you to keep the auto locking/manual locking hubs. Two different parts of the front axle. |
| Sponsored Links |
I had the same thing on my '04 F-350. Found it to be the Drag Link. THe bolt in the frame side is supposed to be torqed to something like 140 ft lbs. You need a torque converter for this and if they don't have one, then this might be at 100 and you turn, lean or bump, and you get a clunk. Have them check the washer too on this drag link bolt. It is supposed to be an offcenter washer to assist holding the bolt in place. But Ford's replacement bolts and washer for this are std washers allowing clunk.
Last edited by tysonmathews : 12-19-2007 at 11:00 AM. Reason: phat fingered reply |
drag link huh?? well just got a call from dealer saying its done i asked what was done this time they said, it needed new sway bar bushings and that the clunking is gone!! yea right that was said too many times already..... but i will see when i pick it up.. also that the inner bearing was greased and the grinding is gone ..yea right i wont believe it till i pick it up later and drive it.. if this has to go back for the 7th time im going to lose it ![]() ![]() ![]() ![]() ![]() : Rant:![]() ![]() i will take a test drive and let all of you know wish me luck.. ps:what is a inner bearing and is it greaseable?? |
ah man i am dying to find out abot this now....i would be SO ticked being out of that money and so many trips!!!!!!!!!!!!!!!!!!!!!
| Sponsored Links |
