Major smoke while at idle and under acceleration - Ford Powerstroke Diesel Forum
post #1 of 13 Old 02-15-2013, 05:19 PM Thread Starter
geoff426's Avatar
Hi all-
So amongst my other problems this started the yesterday.
Really rough start up. Really rough while warming up and blowing smoke all the time, alot of smoke. I have a video but dont know how to load it on here. Then while driving, under acceleration it blows a lot of black sooty smoke. I mean I can cloud the expressway like James Bond pulling the smoke screen lever. I do have a code P0281- Cylinder 7 contribution something or other. I assume its an injector. There's a lack of power when it comes of idle sometimes, not all the time, then boost picks up and it takes off. Am I right to assume that is all it is. I will order some rev-x tomorrow.
Ford checked my batteries a couple weeks back and said they failed some test of theirs. I still havent bought new ones obviously. (I will in the morning now) They havent shown anything out of the ordinary on my monitor and always seem to have plenty of cranking power but now Im seeing a " what do I know" situation. I am concerned about my FICM if they are in fact bad. Ficm voltages are always between 47.5-48.5. I am not sure on cold start craking though what it gets to. I will check that in the morning. But I have read bad batteries can kill an FICM. My repair tab keeps going up I guess.
If there is anything I am missing or am forgeting to mention to confirm my suspicions please ask me.
Thanks Much
Geoff
geoff426 is offline
post #2 of 13 Old 02-16-2013, 06:21 PM
southend's Avatar
Re: Major smoke while at idle and under acceleration
Perform ficm test on a cold engine only, after you load test the batteries. Rev-x will only help with cold rough start. What type of monitor do you have? Sounds like a bad ficm and bad injector, overfueling will damage your engine if you keep running our like that. You should also pull your egr and inspect it.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 13 Old 02-17-2013, 09:21 AM Thread Starter
geoff426's Avatar
re
Ok so I took my batteries out Saturday morning and up to my local Autozone. They said they tested the batteries and gave me a print out showing the batteries are good. I did have the truck plugged in but never attempted to start it before removing them.
Now its Sunday morning and I did not have the truck plugged in, went out to attemp to start it and the battery volts seemed low. I think it was 11.4 with the key on engine off, about 10* outside. I am going to try to put a video up through you tube. It started up just fine though
Here is the video hopefully-
Lets see if that works
geoff426 is offline
post #4 of 13 Old 02-17-2013, 09:31 AM
southend's Avatar
Your voltage is normal during starup with the glowplugs on. The glowplugs will stay lit for up to 2 min, depending on engine temps. You still should check your ficm voltages with a cold engine, less than 45v is a sign of ficm failure.
southend is offline
post #5 of 13 Old 02-17-2013, 09:37 AM
05_PSD_Erik's Avatar
That doesn;t sound good at all! I would suspect for sure an injector (or two) and possibly an FICM, but the FICM voltage looks good on the monitor, so I would say at least one injector, but sounds like more than one...
My injector failed on my way home from the beach and I returned the truck to a stock tune and drove it easy home and it drove fairly okay, a lot of vibration at idle you could feel, but the truck built boost and everything fairly decent for a dead cylinder. What I did was took the truck to Ford and had them run an injector test with their computers so I could tell which injector was bad and make sure I didn;t have any others failing soon after I replaced this one. Cost me like $100-$120 for this scan.
This is what my 6.0 sounded like from a "cold" start (sitting overnight not cold temps) with one bad injector. You can really hear the miss when I first started to increase the RPMs. Yours probably sounds SO bad because of the cold outside temp coupled with bad injector
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #6 of 13 Old 02-17-2013, 09:51 AM
taskforcefreddy's Avatar
Need to check ICP/IPR voltage and Percent. Am suspecting your IPR Valve might be bad. Your device should be able to check that. You don't have enough oil pressure in your HPOP system to cycle your injectors.
Sent from AutoGuide.com App
taskforcefreddy is offline
post #7 of 13 Old 02-17-2013, 09:58 AM Thread Starter
geoff426's Avatar
re
Here's the EGR valve, How bad is that?
geoff426 is offline
post #8 of 13 Old 02-17-2013, 10:01 AM Thread Starter
geoff426's Avatar
re
[quote You still should check your ficm voltages with a cold engine, less than 45v is a sign of ficm failure.][/quote]
What the monitor reads before I start it isnt correct?, Sorry if stupid question I just dont know.
geoff426 is offline
post #9 of 13 Old 02-17-2013, 10:14 AM Thread Starter
geoff426's Avatar
icp voltage
Well I changed the "pid" and the voltage reading for that was .2 with the key on and enginge off. I started it up and it fluctuated around 2.+ something. I then shut it off to see if I would have a consistant read on it and now it won start again. It turns over for a few seconds then the starter just kinda free spins. Hmmm.
geoff426 is offline
post #10 of 13 Old 02-17-2013, 10:18 AM
southend's Avatar
What the monitor reads before I start it isnt correct?, Sorry if stupid question I just dont know.[/QUOTE]
I apologize, I didn't look at the video before i said that. It looks good. Ficm logic board can also fail, it's rare, and honestly i'm not sure how that is checked. The other suggestions need to be checked also.
southend is offline
