Need help ASAP again :/ - Ford Powerstroke Diesel Forum
Old 02-10-2013, 07:04 AM
I noticed my truck runs a little rough before it gets up to 180* ect and 188* eot. I have no codes checked it twice. My edge cts shows no codes either. Good ficm 48.5-47.5 all day long. It seems to be bucking. I just changed fuel filters and it didn't help. It don't seem to be getting any worse it's just annoying. Once it's up to 180-188 I can run a 1/4 in 14.4sec. I don't know what to look for next. Working on buying a new house I really don't want a big problem cutting into my downpayment funds.
Sent from AutoGuide.com App
Old 02-10-2013, 07:09 AM
Almostdunfukinwidit
Add some rev x
Old 02-10-2013, 07:12 AM
I have archoil
Old 02-10-2013, 09:13 AM
Any other suggestions?
Old 02-10-2013, 10:27 AM
Powerstroke Techie
Feedback Score: 3 reviews
injectors? don't feel bad, I need them too and the trucks not even at 90k yet
Old 02-10-2013, 11:14 AM
Powerstroke Techie
EBP sensor, EGR, ICP sensor especially if early build...
The list goes on and on. You need to monitor some data to be sure.
See what ICP EBP BARO MAP are reading key on engine off.
Old 02-10-2013, 05:10 PM
I agree with sinner6.0. Get it scanned; you will probably find you need a new injector.
Old 02-10-2013, 06:36 PM
Its been scanned twice and not showing any codes. I left it with my mech overnight he said he wanted to drive it while its cold and run a scan on it while cold then when at opperating temps. so we might have something to go by after lunch tomorrow. Thanks for all the info. Ill post the findings when i get them
Old 02-11-2013, 12:00 AM
MAD - Modification Addict
Feedback Score: 7 reviews
Spool valves in the injectors are sticking.
Old 02-11-2013, 05:41 AM
Originally Posted by King Rancher_27 View Post
Its been scanned twice and not showing any codes. I left it with my mech overnight he said he wanted to drive it while its cold and run a scan on it while cold then when at operating temps. so we might have something to go by after lunch tomorrow. Thanks for all the info. Ill post the findings when i get them
Scanned means with a contribution/balance test or maybe just a simple injector buzz test followed up to confirm with the C/B test will find the culprit cylinder. Stiction does not show as a code unless it is real bad. Doing it cold is usually the best time to catch it.
