low icp v and icp press - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-09-2013, 05:39 PM Thread Starter
jwsland's Avatar
My icp v is reading .8-.9 at idle. Icp psi reads 570-600 occasionaly dropping to 530-540. Truck idles poorly, sounds like its misfiring or injectors are not firing properly. Only does this in park, runs fine in drive. Brand new icp sensor. Ficm voltage is reading 50v io Edge cts (58v ficm).
06 F.350 Lariat. Daily tower.
Suncoast Trans, MTW Stage 2, Warren 175/75's
Tuned by Tony Wildman- 515rwhp/973rwtq
06 F.550 4WD 12ft Rugby Landscape Body
97 F.350 Reg Cab 7.3 New Trans w/ upg. converter, no cat, AFE intake.
jwsland is offline
post #2 of 7 Old 02-09-2013, 06:06 PM
10secondC's Avatar
Sounds like a small HPO leak somewhere. Mine will idle at .9v but holds steady at 570/580. If your dropping to 530 and it's stumbles you have an issue.
2007 XL CC,DRW,4x4.
When I die I wanna go peacefully in my sleep like my Grandpa, not screaming in terror like the passengers in his car.
10secondC is offline
post #3 of 7 Old 02-10-2013, 01:49 PM
Mine when at operating temp fluctuates 0.7-0.9 when idling in drive... No idling issues. Sounds like an injector issue? get the IDS on it so there is no guessing involved
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #4 of 7 Old 02-10-2013, 02:33 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Those numbers are completely normal. I told you what I thought your problem was didn't I? I recall we had a pm conversation about it?
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 7 Old 02-11-2013, 03:15 AM Thread Starter
jwsland's Avatar
Yes you did and I've already made the phone call. He said its normal and I need new tuning and ficm tuning. Not the route I want to go. Just want to make sure 100% it can't be something else.
Am I the only guy who had had 3 sets of warren injectors in 6 months! This is riduculious. Don't want to mask this problem with computer tuning.
Very frusterating not being able to let my truck idle in the winter because its shaking and sounds like its breaking down. Everyone asks whats wrong with my truck too, ughhhh
jwsland is offline
post #6 of 7 Old 02-11-2013, 07:45 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
That is not normal. I have his injectors and mine do NOT idle like that at all. They idle like stock sticks do. Try one thing. Have a tune writer write you a file with the idle kicked up to around 900 Rpms and see what happens. Tell them that is all you want revised in one of your current tunes. That will answer the question on my theory.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #7 of 7 Old 02-11-2013, 04:00 PM
nice info^ I know my injectors are not as big but do you think matt wrote my tune like this? Just wondering as im going up to 175's maaaybe 190's
bpd
Warren comp trans
04cr450 is offline
