Starting issues (with updates) - Ford Powerstroke Diesel Forum
Old 02-06-2013, 07:34 AM
Truck got a oil change, fuel service (which it realy needed) and Cat & muffler delete. Truck runs better but...
Truck doesn't like to Hot start and doesn't like to cold start. If plugged in it will start first try but with foot to the floor. Only chance at hot start is again, foot to the floor.
What would cause it to only start if your foot is in it? Once it is running it seems to be fine.
Old 02-06-2013, 07:43 AM
Conservative and Proud
Old 02-07-2013, 09:07 AM
Bump, truck will only start with foot on throttle. Hot start much worse than cold start.
Old 02-07-2013, 04:45 PM
Re: Starting issues (with updates)
Load test your batteries and perform the ficm check procedure cold. Do you have a monitor? Are you using motorcraft filters and oem caps? Need a reading on icp, ipr.
The ford manual says to hold the pedal to the floor, if it is not starting, to shut the fuel off to prevent flooding. Not sure how you holding the pedal to the floor could help in your situation.
Sent from my phone that somebody didn't help me get.
Old 02-10-2013, 11:18 AM
Not sure either. I'm getting it scanned at the dealership this week.
Foot to the floor it will start. If I don't touch the gas pedal it just cranks and cranks with a no start.
Old 02-10-2013, 05:07 PM
When it starts does it blow a lot of smoke for 15 seconds or longer? As Southend said, the foot to the floor is really not a player, unless you have injector nozzles that are not closing and are letting in fuel that is fouling the cylinders for a start.
Old 02-11-2013, 06:56 AM
No, no smoke on start. I tryed a somewhat cold start yestedday wthout the throttle and it cranked for a while and then it did start so maybe the foot on throttle realy isn't helping.
I had it scaned yesterday. noly codes of intrest were injector 1 and 6 low voltage circuit or somthing like that.
Old 02-11-2013, 09:38 AM
Is this a 7.3 or a 6.0? Checked your sig. It is starting to sound like a IDM (7.3), FICM (6.0), 2 injectors, or wiring issue.
Old 02-12-2013, 04:04 AM
2005 6.0
long crank to start cold. Hot loooonnngg crank or no start.
Old 02-12-2013, 06:12 AM
Originally Posted by roccodart440 View Post
2005 6.0
Undoubtely, you have more than one problem, but I would include hpo leak, hpop failing.
