Inside of coolant bottle - Ford Powerstroke Diesel Forum
Old 01-31-2013, 04:32 AM
All the issues I have and my coolant bottle was even one of them. The threads were messed up from my cap. It blew off one time. Its been changed a few times, taken off two hundred times when the truck has been worked on. Well I cut the bottle open and heres what the inside looked like.
Old 01-31-2013, 05:06 AM
Wow looks like you need a flush bad. I noticed your signature says bulletproofed does that also mean an oil cooler? Even if you have a bulletproof oil cooler I would flush my cooling system to get all that junk out of it.
Old 01-31-2013, 05:11 AM
Looks like typical engine oil cooler failure...
Old 01-31-2013, 05:20 AM
Truck was flushed for 12 hours with restore/ restore plus. Coolant filter and brand new oil cooler. Using CAT elc. Eot and ect never get more than 5 degrees apart. I think the bottle was ditry from before I flushed.
Old 01-31-2013, 05:33 AM
It is possible that is from before the flush. A lot of us don't think about checking degas bottle after or during a flush.
Old 01-31-2013, 06:33 AM
Now to put it in perspective. If the degas has that kind of crud in it, just think how much was in the hoses, heat transfer devices, and the engine. It's great you are getting it all sorted out.
Old 01-31-2013, 08:16 AM
True, The hose on the bottom of the bottle looked clean. I change my coolant filter often and always cut them open. They paper is always dirty but never any of that gunk in there.
Old 01-31-2013, 12:16 PM
Thumbs up
That's a very good thing then.
