Idle issues. Desperate! (video) - Ford Powerstroke Diesel Forum
post #1 of 33 Old 01-30-2013, 10:41 AM Thread Starter
jwsland's Avatar
175/75 idle - YouTube
175/75 idle 2 - YouTube
Truck idles like crap in park. Diag from my shop shows 4 injectors are not firing in park. The truck runs phenominal in drive. The injectors are about a week old from Warren Diesel. FICM is a non tuned 58v, showing 50v on my insight. No dtc codes or injector codes.
Any other specs needed to determine this problem that I can pull from my insight?
06 F.350 Lariat. Daily tower.
Suncoast Trans, MTW Stage 2, Warren 175/75's
Tuned by Tony Wildman- 515rwhp/973rwtq
06 F.550 4WD 12ft Rugby Landscape Body
97 F.350 Reg Cab 7.3 New Trans w/ upg. converter, no cat, AFE intake.
jwsland is offline
post #2 of 33 Old 01-30-2013, 11:50 AM
Brent Beeler's Avatar
A friend of mine has an 03 sounded the same, he replaced the ICP sensor and it fixed it. What's the HPOP psi look like at idle?
Sent from AutoGuide.com App
Brent Beeler is offline
post #3 of 33 Old 01-30-2013, 12:08 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
You know it's funny. Shack (OneBadCoastie) has almost the same problem with his new 175/stock injectors from Warren. PM me for details.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #4 of 33 Old 01-30-2013, 12:10 PM Thread Starter
jwsland's Avatar
Hey its not funny! haha pm sent
jwsland is offline
post #5 of 33 Old 01-30-2013, 12:15 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
PM returned.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #6 of 33 Old 01-30-2013, 07:15 PM
Well?? What ended up being the problem?
post #7 of 33 Old 01-30-2013, 07:19 PM Thread Starter
jwsland's Avatar
Not sure. I don't even know where the icp sensor is located or how to monitor hpop related parameters on my inisght. Someone here asked what my ipr reading was and I guess my monitor doesn't read that. I'm leaning towards lost cause though. Guess I'm pulling on the dyno Saturday with injector problems for the second time.
jwsland is offline
post #8 of 33 Old 01-30-2013, 08:06 PM
Please let us know when you figure it out.
post #9 of 33 Old 01-31-2013, 04:41 AM Thread Starter
jwsland's Avatar
If theres no code on the icp sensor then its not "bad" right?
jwsland is offline
post #10 of 33 Old 01-31-2013, 06:48 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
No, the codes for ICP only show up for sensor issues (shorted, low or high voltage) or if it is way off from expected.
You have an 06, so the sensor is on the right valve cover just aft the GPCM. I don't have an Edge Insight, but I thought you could get those parameters on it? Without the info, we are all just shooting in the wind to help you find the problem.
When did you change the injectors out? It is possible you still have some air in the HPO system. It is also possible you have a small HPO leak that at higher pressure is not as obvious, yet.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
