Coolant Leak-Need Help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-30-2013, 09:47 AM Thread Starter
usmcknight69's Avatar
Ok, I know its been discussed on here a bunch. Just looking for some help/opinions.
My truck has been studded and changed the head gaskets. Did a coolant flush and coolant filter about a year ago. Replaced coolant with Cat ELC Concetrate.
I monitor all my temps very closely. I was driving around today and started smelling coolant through the vents. Stopped to check it out and found coolant leaking from under passenger side area. It looks like it is leaking from the starter area. Checked the top of the block and it is dry......any ideas/suggestions?
Thanks in advance
***MOLON LABE***
2005 F250 SCREW LARIAT 6.0L
ARP STUDS, GASKETS, SCT CUSTOM, AFE STAGE II
10" LIFT, 38X14X24 KUMHO MUDDERS
MKW WHEELS, AMP RESEARCH STEPS
4:56 F/R GEARS, 5% TINT, CLAYMORE HITCH
PHANTOM II VOLTMETER, BOOST, EGT
TRANS TEMP, 2 12" KICKER COMP SUBS,
PIONEER AVIC Z130, RECON TAILS, 3RD BRAKE &
CAB LEDS, HID 6000K HEADLIGHTS & FOGS
UPFITTERS, EXTANG REVOLUTION LO PRO, MBRP DUALS
W/O CATS
usmcknight69 is offline
post #2 of 8 Old 01-30-2013, 10:05 AM
King Rancher_27's Avatar
It could be the blue hose going to the oil cooler from the egr cooler/egr delete tubing. That's where I had a leak. It was hard to see on the block but you could see droplets on starter and Trans lines. Hope this helps
Sent from AutoGuide.com App
-Casey
2012 F250 FX4 stock with 3.55 gears
2006 F250 King Ranch FX4--SOLD
ARP Studs-OEM gaskets(this time
SCT with IDP tunes,Gearhead tunes & TSD TUNES
EDGE CTS insight
5" TB with 6" Tip no kitty or muff
Sinister Delete Kit
Upgraded oil cooler
leveled w/ 295/70/18 Nitto Trail terrian
6.4 banjo bolts
Blue Spring Upgrade
KC Stage 3 68mm Turbo
Ported Intake
S&B CAI
190/75 Renagade injectors
STC fitting
King Rancher_27 is offline
post #3 of 8 Old 01-30-2013, 10:58 AM Thread Starter
Thanks for info. I checked as best I could and I cant tell. That is definitely the area it is leaking from. Just dropped it off at Ford and im gonna have my buddy check it out. Ill post when i find out what it is.
***MOLON LABE***
W/O CATS
post #4 of 8 Old 01-30-2013, 11:18 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
Barring you finding the Sinister delete leaking, if the top of the block is dry, how about the hoses or connections to the heater core?
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #5 of 8 Old 01-30-2013, 11:41 AM Thread Starter
My buddy at Ford said he is going to check the hoses. I tried to check at my house, but between the rain and 40* weather, I didn't feel like becoming an ice cube. Dropped it off at Ford a while ago and my buddy said it sounded like possibly the hoses near the heater core. Ill keep ya posted. Thanks for response
***MOLON LABE***
W/O CATS
post #6 of 8 Old 02-04-2013, 03:45 PM Thread Starter
So i got some updated info today....I was told it was the oil cooler that is the problem along with a few o-rings and gaskets! Any idea what o-rings and gaskets their talking about???
***MOLON LABE***
W/O CATS
post #7 of 8 Old 02-04-2013, 06:07 PM
Quoted: 46 Post(s)
Gasket on the top of the cover near where the turbo oil comes out the block or the whole cooler cover. O-rings for the cooler coolant side.
Frank
Working for Toys
post #8 of 8 Old 02-07-2013, 12:25 PM Thread Starter
Turns out it was just the gasket and o rings for the cover....cooler was fine.....still cost a cool $1200 to fix! Should have the truck back tomorrow or monday. I would have fixed it myself, but I just dont have the time right now.
***MOLON LABE***
W/O CATS
