Is she studded??
I have an 06 6.0 and I bought it a little over a year ago with 165,000 miles. I've put 20,000 miles on it so far with only the FICM going out. I know from the oasis report that the oil cooler was replaces at 65,000 miles, head gasket at 120,000 and at some point, an EGR delete. I have just been nervous about about if she has been studded when they did the gasket or they put TTY bolts in. I was thinking that if I took off one of the valve covers I could tell if they are TTY or Studs. Do y'all agree??
Don't need to pull valve cover. Look from drivers side, tty are bolt heads, arp are nuts with threaded bolt
sweet thanks!
Agreed
u can see them at the bottom stud with nut vs bolt |
Thanks for your help yall ... She still has the TTY bolts .. looks like i have a new project to save for...
Maybe, maybe not
161000 on original TTY here (knock on wood). And run srl, looney, extreme street, you name it. |
