EOT at 225 in town!!??? - Ford Powerstroke Diesel Forum
Old 01-25-2013, 12:24 PM
Just got a dash boss, my eot is 225 in town and ect is 190. EOT seems a little high. Is it????? Did a BPD egr and ford oil cooler less than a 1 yr ago with new coolant ELC. Can my cooler be plugged again??? I have been having issues with puking coolant when climbing.
Gb
Old 01-25-2013, 12:31 PM
Sounds like a plugged oil cooler bud. The only right way to go is with a BPD oil cooler imho. You pay out your butt but you should never have to worry about it again.
Old 01-25-2013, 12:32 PM
Send a message via Skype™ to kendallcschm
i agree.. he can try to clean his oil cooler but its not really worth it.. what coolant are you running?
Old 01-25-2013, 12:35 PM
Kendallcschm brings up a good point. Although Ford does not recommend it the Ford Gold coolant has known issues that most people agree causes the plugged oil coolers. You need a coolant such as Rotella ELC or Fleetrite (International's brand) ELC that does not have the same issues to plug up oil coolers.
Old 01-25-2013, 12:44 PM
Gb
Just pointing out that your sig states you have a sinister egr cooler and in your post you stated BPD??? So which is it??
Old 01-25-2013, 12:55 PM
Re: EOT at 225 in town!!???
Might be a stupid question... But did you check your coolant level?
Old 01-25-2013, 01:04 PM
No such thing as a stupid question...
Old 01-25-2013, 04:05 PM
I am using rotella elc and i think the egr cooler is sinister. Oops!
Old 01-25-2013, 05:04 PM
MAD - Modification Addict
Feedback Score: 7 reviews
Is it pouring white smoke after it starts up with the engine already warmed to operating temp?
Oil cooler is definitely clogged and if it has been that clogged for a while it's a good possibility it clogged and ruptured your egr cooler. BPD it up man go with a BPD oil cooler kit and egr cooler and call it good unless you have pushed a head gasket.
Old 01-26-2013, 10:11 AM
What if a guy had used bars leak in the radiator a few months back to fix a leak???? Would vc9 clean that out??
