I Have A Leak!! - Ford Powerstroke Diesel Forum
Old 11-22-2007, 07:48 AM
Send a message via Yahoo to dieselpowered
I Have A Leak!!
Seems that I have inherited a leak right behind the oil pan...forgive me, I do not know what it is called.
Anyhow, I seem to remember people speaking of leaks on their 6.0's any thoughts?
The area I am speaking of seems to mate up to the tranny.
Thanks in advance!
Old 11-22-2007, 07:52 AM
lifetime member
does it actually drip. could be assembly lube, black and gooey and no drip.
Old 11-22-2007, 07:55 AM
Appreciate the response.
Actually it does not continuously drip...I have only noticed two drops on the driveway, after looking at it, it appeared that it was collecting enough again to drip?
This is the first time it has happened...I wiped it away and will check it again after driving.
Old 11-22-2007, 08:01 AM
lifetime member
check to make sure. i am not doubting you, but i have read on here somewhere that it sometimes looks like oil leak but is not.
Old 11-22-2007, 01:31 PM
i just had a leak similar to this. at first i thought the rear main might be leaking, but it ended up being the ICP sensor. warranty fixed this problem.
