Any help will be appreciated!! - Ford Powerstroke Diesel Forum
Old 11-19-2007, 09:18 AM
Friends 06 PS turns over several times before it cranks.Other than that runs fine.Is this normal for a 6.0?? Has 93k miles
Old 11-19-2007, 09:34 AM
I don't know nuttin....
Has it had the latest pcm flash from Ford?
If not, take it in and do that.
Old 11-19-2007, 09:37 AM
Not really sure, is that something that would be covered under warranty?
Old 11-19-2007, 09:45 AM
If your not sure then it probably hasn't been done. How long have you owned it?
I think it should be warrantied.
This latest program is set up to help with cold starts by throughing higher voltage to the injectors upon start up and it has really helped alot of 6 ohs.
