egr cooler problem?
Ok..I've had this issue w my rig for a while and I was told the egr cooler is bad..truck starts fine and idles fine..just absolutely hardly any power..my egr valve is wet ..which I know there is a problem there..but would it cause the truck to have no power? When I put the sct tune on it its almost like when I try to accelerate the truck almost shuts off and comes rite back on..almost like a surge..but not a Turbo surge.. I've got a river city diesel egr delete..bpd.ficm..and new bpd remote oil cooler to install in it..I just hope this will fix the problem ..ill let y'all know when the stuff is installed. Just wondering if anyone had a similar problem like this and what they did to fix it. O yea..just had all 8 injectors replaced so I don't.think there is a problem there. I attached a pic of the egr valve hole..
The no power can definitely come from the EGR cooler being blown and allowing coolant into the cylinder. The items you have purchased should resolve your issue and give you some excellent reliability. Since you are already in there, you might want to consider replacing your head gaskets, confirming your heads are good and getting head studs because that is also common on trucks with blown EGR coolers. Since coolant doesn't compress, that pressure usually ends up escaping through the head gasket. At the very least, you need to test to make sure your head gaskets aren't blown.
Best of luck, buddy and as you probably already know, there are a BUNCH of install threads that can walk you through how to remove and replace this stuff yourself with LOTS of pictures. |
Re: egr cooler problem?
Also check your map sensor port and hose connected to the right side manifold.
Sent from my phone that somebody didn't help me get. |
a lot of times the goo from mixing coolant and carbon will quickly clog a valve up. an excessive buildup of dry carbon is not too common.
Dry carbon and oil mist from the ccv is a problem, was on mine.
I plan on getting the EGR delete installed along with the BPD oil cooler kit and BPD FICM and then throw my pressure tester on there to see what it does on the cooling side. I also plan on hooking my Dashboss up and seeing what I can find for him before we tear into it. We will keep you guys updated. lol. |
Good to hear, Bryan. Glad that he has someone like you who knows what's going on to help him out.
Ya..me too..LOL.. if it wasn't for Bryan I would have got rid of it a few years ago..LOL..he's a great guy
