Battery Problems? - Ford Powerstroke Diesel Forum
post #1 of 35 Old 01-18-2013, 08:55 AM Thread Starter
Arrow Battery Problems?
The last week my truck has had problems starting in the morning because of what I assume are battery issues. This is because once I hook up my battery charger for 30-1hr it starts right up.
I had the batteries tested 2x and both tested good under load.
Still having this issue with dead batteries in the morning. Only thing that has been different around here is its been down in the 40's during the night time. That is nothing to most of you, but maybe my truck does not like it
Any thing ya'll think I should look at let me know, and I will report back.
2006 F-250 PS CCSB King Ranch
6" Fabtech Lift
Bilstein 5100's
35" Falken Rocky Mountain AT/S on 20" Pro Comps
EGR Delete - Performance Machine mfg.
Updated Oil Cooler
6.4 Banjo's
Updated Larger Turbo Oil Drain Tube and Feed line
"Blue Spring"
AFE Stage 2
SCT Livewire - "Looney Tune"
4" Turbo Back Straight Pipe
Updated Dummy Plugs & Stand Pipes
Roll-N-Lock Bed Cover
Train Horn (get off your cell phone horn)
Zoodad
more to come as the hours go by...
TheOne is offline
post #2 of 35 Old 01-18-2013, 08:58 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
are your battery's drained as in completely gone,dead? Or just weak?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 35 Old 01-18-2013, 09:02 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Re: Battery Problems?
Maybe batteries, connections, starter, ficm, oil, or anything heui related
I made my Samsung SGH-I997 send this.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 35 Old 01-18-2013, 09:03 AM
ZMANN's Avatar
Quoted: 1587 Post(s)
since they are dying anyway try unhooking the two grounds and then see what the batts crank llike in the AM this will verify if it's a battery or discharge issue easily
We Miss you Ronnie
ZMANN is offline
post #5 of 35 Old 01-18-2013, 11:34 AM Thread Starter
this AM when I went to start, it just barely cranked a few times sounded as if a weak battery.
That is how is been every AM for the past week.
I will do this if I have the problem tomorrow morning. Because I put the battery charger on this AM after trying to start.
6" Fabtech Lift
Bilstein 5100's
Updated Oil Cooler
6.4 Banjo's
"Blue Spring"
AFE Stage 2
Zoodad
TheOne is offline
post #6 of 35 Old 01-21-2013, 07:14 AM Thread Starter
So it just turns out to be low batteries in the AM. They just slowly try to crank the motor.
I put my charger on them, and they go.
But I start and drive my truck around for about 30min and then park it for 8hrs and the next morning the batteries do this slow/weak start to me.
Does that mean I have a bad charger?
Bad Battery?
6" Fabtech Lift
Bilstein 5100's
Updated Oil Cooler
6.4 Banjo's
"Blue Spring"
AFE Stage 2
Zoodad
TheOne is offline
post #7 of 35 Old 01-21-2013, 07:36 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Idk, test batteries and the alternator.could be both
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 35 Old 01-21-2013, 05:07 PM Thread Starter
Both batteries have tested good.
Need to test the alternator for sure
6" Fabtech Lift
Bilstein 5100's
Updated Oil Cooler
6.4 Banjo's
"Blue Spring"
AFE Stage 2
Zoodad
TheOne is offline
post #9 of 35 Old 01-21-2013, 06:16 PM
ByronCR's Avatar
Quoted: 7 Post(s)
If it was your alternator, you typically would see your battery light come on. When I had a stock alternator on my truck, it would put out 11.5 volts and my battery light would come on until the truck would bump up over 12. Eventually the alternator just quit bumping up over 12 and stayed around 11 to 11.5 and my battery light would just stay on.
I'm not saying you don't have a bad alternator, but usually your battery light will come on if that is the case. Sounds like you have something drawing power. You add any electronics or do any maintenance / mods lately?
Ordered: 2017 F350 PSD CCLB Lariat FX4 - Est Delivery End of December 2016
1974 F250 Highboy 4x4
V8 390 w/ 4 barrell Holley carb, Electronic ignition system, Dual Exhaust, Winch
ByronCR is offline
post #10 of 35 Old 01-22-2013, 05:44 AM Thread Starter
I have not done anything new lately.
I also do not have the battery light come on once the truck is started. Its on when the key is turned and I wait a sec for the glow plugs to warm.
I did clean my battery terminals not to long ago because of some corrosion, and after that my alarm on the truck the siren stopped working. I have still not been able to track that down to a loose wire or anything. Still on the hunt for that cause. Maybe the two are connected but I doubt it.
6" Fabtech Lift
Bilstein 5100's
Updated Oil Cooler
6.4 Banjo's
"Blue Spring"
AFE Stage 2
Zoodad
TheOne is offline
