Couple questions
I noticed my icp voltage started dipping down below .8 at stopights and the truck was running a little rough at times. It just went down to .7. But everytime it did I could feel it.
Does the edge insight have ipr reading capabilites that I'm not seeing? I'm still on my stock hpop at 190k. I'm getting my 175/75's put in very soon. Should I go ahead and have everything done? I know its a big job, and expensive but I just don't want to get stranded again. |
Re: Couple questions
There is an update that lets you read icp psi now on the edge. When was the last time you updated? The psi reading will help diagnose the problem. No it will not read ipr.
Sent from my phone that somebody didn't help me get. |
My monitor is only a couple months old. I can read icp psi. In drive at idle I'm reading 570-590. Not sure what I should be at.
That does appear a little low, I typically see 630 psi. at idle, hot.
What would cause that?
I think a failing hpop our hpo leak. Have you seen the test for the hpop posted in the performance parts stickies?
Just saw it, thanks! The truck goes in for injectors tomm. I'm going to see if they will test it out for me.
