crankshaft position sensor, slow crank?
Will an unplugged or bad crankshaft position sensor cause a slow crank?
I put my truck back together after studs, injectors, etc and it cranks VERY slow. The batts are good, the starter is 1 month old. The only thing I know that's not right is the clip is broken on the crankshaft sensor and the plug will not stay on. I am wondering if this is causing a slow crank. |
Checked starter, it's good.
Removed all glow plugs, still cranks slow, not hydrolocked. Zip-tied crank position sensor plug (for now). Digital battery charger says both batts are 100%. What am I missing? Grounding issue? |
Digital battery charger is not a load tester, get your batteries load tested.
Sent from my phone that somebody didn't help me get. |
1st on the list tomorrow.
With the plugs out it should zing over pretty quick. I'll bet the batteries are weak/bad.
Was it a Ford starter or a parts store piece? Sent from my DROID X2 using AutoGuide.Com Free App |
Gonna have the batts load tested tomorrow. Last edited by willholl79; 01-14-2013 at 05:10 PM. |
So the starter is toast...that'd do it. Hehe
The batteries will take care of it I bet. Sent from my DROID X2 using AutoGuide.Com Free App |
Tested batteries, one was bad, replaced it. Still cranks slow.
Removed, cleaned, reconnect all ground on engine. Still cranks slow. Gonna check voltage at starter. Maybe a bad wire. Any other ideas? |
Other than what you said you was going to check, Batteries should always be replaced in pairs, the "old" one will eventually wear the new one down. A bad starter will "drag" a motor down.
