URGENT!!! NEED HELP! - Ford Powerstroke Diesel Forum
Old 11-11-2007, 12:42 PM
Hey everyone, I'm trying to get my EGR off to clean it before it gets dark outside...I have the two bolts removed, but it's stuck on there...anyone know any tricks to get it off? We have been trying with some channel locks, but all it's doing is scratching the egr valve...lol. PLEASE HELP!!!
Old 11-11-2007, 12:50 PM
Click Click.......BOOOOM!
Egr Valve
Check that out I hope it helps. Im not sure but I think i've heard people talk bout using a crow bar to get it loose.
Old 11-11-2007, 01:00 PM
We just tried that...it seems like it's just bending the edges...any other ideas?
Old 11-11-2007, 01:03 PM
I couldn't get mine off either.
Old 11-11-2007, 01:06 PM
I was reading this other post about unplugging it or blocking it off all together actually being better for the motor. Do you think unplugging it until I can take it to a shop will cause any problems? It should just have the same effect as blocking it off or removing it all together...right?
Old 11-11-2007, 01:08 PM
duh...i posted the c lock thing...two small nail pullers/pry bars right under the ears also works...
if you unplug it you'll get a CES light but it won't hurt anything...
the point of blocking it off is to block it off at the up pipe so the hot exhaust gasses never get to the EGR cooler...helps to keep the coolant from flash boiling when the EGT's are HIGH...
Old 11-11-2007, 01:10 PM
We tried that...but it didn't really work too well. All it was doing was scratching the valve. Maybe we just need some extra elbow grease...
Old 11-11-2007, 01:11 PM
I think unplugging it will through a code. Not sure though.
Old 11-11-2007, 01:14 PM
if all else fails there is an EGR puller available from Ford...it aint cheap, but you could rent it to your friends when you don't need it..LOL
Old 11-11-2007, 01:15 PM
I read a few posts up that the 03's dont throw codes for that...it should only be till the 15th
