Parts list for my headgasket job!!! - Ford Powerstroke Diesel Forum
Old 01-11-2013, 12:37 PM
07 6.0 psd with 71000 miles!!
Making parts list to do hgs this weekend not to do it needs be done!! If you guys see something I'm missing let me no so I can order it but this is what I have collected so far? And win I pull the heads off what do I clean the block surface with read so many reviews on it and seems like no one agrees on anything? Im thinking that's all I need to no at this point thanks for your input!!!
ARP Head Studs for 6.0L Powerstroke
Performance Machine & MFG. Engine Oil Cooler Kit for 03-07 Ford 6.0L PowerStroke
Performance Machine MFG. Powerstroke 6.0L Intake Gasket Set
Performance Machine MFG. 6.0L Exhaust Gasket Set
STC Fitting Update Kit
Titanium Series 20mm Head Gaskets by Performance Machine & MFG.
6.0L Stand Pipe
Ford OEM 04-07 Powerstroke 6.0L Oil Rail Dummy Plug (One Per Side Required)
Old 01-11-2013, 12:40 PM
7.3 4 Ever! Nothing else!
Feedback Score: 7 reviews
Do you need these parts ordered?
Old 01-11-2013, 01:51 PM
You better stick with oem head gaskets. And why are you buying an oil rail?
Sent from my phone that somebody didn't help me get.
Old 01-11-2013, 08:35 PM
Good ? Have no idea lol oil rail where's that located ????
Old 01-12-2013, 05:39 AM
You might want to go here and download the coffee table book, there are some good articles too....http://www.forddoctorsdts.com/
Old 01-24-2013, 03:21 PM
GXP GXP is offline
Two little things - I ordered the same gasket set form Performance Machine MFG. I comes with a ton of o-rings. Most of them don't fit anything. The o-ring for the metal coolant tube (up from the water pump) and the crank case vent are not in there - get those from the Ford dealer before you start. I tried reusing them and ended up with leaks in both spots during initial start up. I would order your gaskets from a reputable company as well. Have had too many problems with Performance Machine MFG. Finally, watch the srmastertech videos on you-tube for oil cooler replacement there are 6 in the series I think). He give a lot of tips that will save you a bunch of heartache! Good luck and post some pics if you can!
Old 01-26-2013, 06:26 AM
Good Luck! I am looking to do the same project to my 05. Are you pulling the cab off the truck?
Old 01-26-2013, 08:43 PM
i think he meant to say oil rail end plugs...aka dummy plugs
