FICM issue??? video
Watch this video of me starting my truck after it sat all night unplugged. it was 25 degrees out. could this be a FICM issue or maybe starter or even injectors???
help me out please |
Did you check the voltage on the FICM? The smoke could be a failed injector or o-ring but I'd go after the FICM voltage first.
Mine does the same thing. I have 3 glow plugs failing and it clears up after engine reaches operating temp. Does it clear up after engine gets warmed up? Have you checked for codes? I bet you have a few glow plugs out. Unless it does not clear up after 10min or so. Then it could be something else.
There are a couple of threads about the same topic I read this past weekend. Sent from my PG06100 using AutoGuide.Com Free App |
I checked it warm and the voltage was good. will check it cold when i have free time.
if it were a injector or o ring the exhaust would smell like straight diesel. But you can always check your ficm too. I think you probably just have a few bad glow plugs or glow plug harness. Sent from my PG06100 using AutoGuide.Com Free App |
So I took it to ford and they are replacing the FICM for $1,100... Hopefully this fixes it.
I've seen where the sct lacks in code reading.
Sent from my phone that somebody didn't help me get. |
I wish i could have but i simply am too busy to wait a few days
