intermittent lose of power
Hey Guys,
my 06 6.0 seems to be stalling. as I raise the RPM, the engine seems to loose all power for a second. as I keep applying the accelerator, the truck drops a couple hundred rpm then up 400 then down 200. I figured it might have been water in fuel or block fuel filter. Took all apart, everything looks to be fine. Can anyone help me out as to what is going on??? Last edited by Amarillo1981; 01-08-2013 at 04:08 PM. Reason: spelling |
Do you have a monitor?
what u mean by monitor??? code indicator? no i dont
forgot to mention that my check engine light is on |
A monitor is a device to monitor your engine vitals. Such as fmc voltage, icp pressure, vgt duty cycle, battery voltage, engine oil temp, engine coolant temp.
External gauges such as egt temp, fuel pressure, and boost. All of these things are nice to have for monitoring purposes. If you have a engine light, you need to pull the codes and see what it is failing. If I were to guess I would say you have a injector going out or a shot ficm. We won't know for sure till you read the codes. Sent from my PG06100 using AutoGuide.Com Free App |
Check this link out.
Write Up: Monitoring the 6.0L PSD. Write Up: Monitoring the 6.0L PSD. Sent from my PG06100 using AutoGuide.Com Free App |
You definitely need to check for DTC's.Several DTC's can cause this type of symptom.
