Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 11-04-2007, 01:47 PM
matt081288 matt081288 is offline
Front End Noise
Hey you guys! I have a 2004 f250 FX4 and when iturn the steering wheel to the left it seems to make a repetative clicking or thumping noise. It only does it when i turn the steering wheel to the left never to the right. You can here the noise in the cab moreso than outside but it is noticeablein both places. It only started doing this after I had my Leveling kit installed and the truck has 71000 miles. But ive checked and nothing rubs any suggestions would be nice. Thanks guys.
Old 11-04-2007, 01:58 PM
cchase cchase is offline
sounds like tie rods or wheel hub, raise the front end and push and pull on the tire if there is play its the hubs, grab the tie rod and shake the crap out of it, if there is play bingo again
Old 11-04-2007, 02:11 PM
There isnt any play whatsoever in the wheel. But where is the tierod located? thanx for the advice cchase.
Old 11-04-2007, 04:54 PM
well, I am not sure if our trucks differ here. but it should be the same concept. Find the power steering pump, and follow the rods down, the tie rod will come acros the front axle and turn the wheels.
Old 11-04-2007, 05:09 PM
Dave Dave is online now
Obama sucks
Take a look at your sway bar end link bushings I bet they are worn out. I just went through the exact same thing with my rig
Old 11-04-2007, 05:11 PM
The tie rod and the wheels are all tight... But there is a rod that connects up to the steering column ( maybe pittmann arm) but when u shake it the joint makes a clicking or clanking noise... i am going to try to replace that piece tomorrow... and see if that is the problem... any more suggestions would be helpful... that is the only thing under the front end i can find that makes a noise...
