Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 11-03-2007, 06:53 PM
CH47pilot CH47pilot is offline
No electrical power
Hello. I have a 05 f250 power stroke turbo diesel. I have been deployed for 15 months and my vehicle has not been started in atleast 2 months. I went to start it today and it was completely dead. I tried to use a portable battery booster but it didn't have enough power. I went and tried to jumpstart it with another f250 and now I get no electrical power. All connections were correct and there is no corrosion. Did I blow a fuse somewhere? If so which one. Any help would be greatly appreciated. By the way, I have a dual battery system, does it matter which battery I jumpstart?
Old 11-03-2007, 06:57 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Possible the batteries are completely dead after two months and might not even take a charge. Do you have a volt meter to test the batteries to see if they have any voltage?
Old 11-03-2007, 07:01 PM
2005F250 2005F250 is offline
You'll need to charge the batteries for a while. Prob. 2 hours.
Old 11-03-2007, 07:02 PM
I tried to charge the batteries but neither one would take a charge. I should still be able to jump start though. Even with jumper cables I have no power going to the vehicle.
Old 11-03-2007, 07:04 PM
Not if your batteries are dead and don't try to jump it without batteries. Your batteries could have dead shorts in them. If they won't take a charge get two new ones
