2005 F250 No Crank (Urgent) - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-02-2013, 09:08 AM Thread Starter
I woke up this morning and it was 17 Degrees, Tried to start my truck with no luck. All the bells and whistles come on, batteries should have plenty of juice (Dropped to 11 when glow plugs were warming), but I had no crank.I do not plug the truck in, but from everything I know that should not cause a no crank situation. I should have tried these simple things but I was in a hurry.
History: 90k Miles, Truck has new alternator, Rebuilt FICM, EGR Valve, Fuel Filters / Oil Filters, New Coolant, thermostat - All within the last 2k Miles (Bought it used and tried to go thru it as best as I can without breaking the bank.) The truck has run great once I got the new FICM and Thermostat
I replaced the alternator because Autozone tested my starter, batteries and Alt. a couple of weeks ago (I was trying to avoid this situation, stupid me) and said everything was good but that.
I am going to try these things when I get home, but would like to know what esle to look for.
Things I know to try:
Read the codes
Shift into Neautral / Move Shifter
Tap on the Starter (See if it is locked up)
Try jumping it??? Can I jump it with a car? That shouldnt hurt it at all?
Look for Wires that may be cut
Things I am currious about and dont know how to check:
ICP
IPR
Please help! I would like to fix this without going to the shop because I hate admitting defeat!
Leopold is offline
post #2 of 3 Old 01-02-2013, 02:49 PM
southend's Avatar
Very likely your batteries, bad batteries kill ficms real quick. Batteries can hold 12 v and not have enough ampreage to crank. Are you saying it's not cranking, or cranking and not starting? What kind of monitor are you using?
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 3 Old 01-03-2013, 03:56 AM Thread Starter
I am using a Edge CTS Monitor, and I saying it is not cranking at all. I checked all the relays, fuses, tried moving the shifter, and everything else I could find last night. Finally I tried to jump the starter directly and I got nothing. I tested to see if I was getting power from the yellow and blue cable to the starter by lightly touching the back of the starter with a screwdriver and found that plenty of power was making it down.
So I pulled the starter to have it tested again, but this time at Oreillys on there machine (even though it was tested while on the truck at autzone), Low and behold it would extend but not crank. I ordered a new starter and will put it on tonight.
Once that is done I will post if that was my solution.
Thanks!
Leopold is offline
