03 no start - Ford Powerstroke Diesel Forum
post #1 of 18 Old 12-31-2012, 07:49 AM Thread Starter
powerstrokecrzy's Avatar
Quoted: 241 Post(s)
03 no start
I tried searching and couldn't find exactly what I was looking for. First off This is my dads truck and he's to stubborn and cheap to buy a scanner. Anyways truck wouldn't start cold. Llc the starter trying to start it. Pulled the codes and showed a nab glow plug module. Replaced that, got him to put in some t6 with hot shot secrets. Replaced fuel filters. It cranked and run for so minute then died, guess once the glow plugs shut off. Now it won't start, acts like it wants to fire but won't run. I checked the ficm voltage and it tested perfect. Mind you he doesn't change the oil like he should and it has always been extremely cold natured. I'm thinking the injectors are just so gummed up that it just needs to run and with the t6 and hot shots it'll clean it up some. Icp and pigtail was replace about a year and half ago. I'm all out of ideas, what yall think?
Sent from my DROID X2 using AutoGuide.Com Free App
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #2 of 18 Old 12-31-2012, 08:07 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
How did you test the FICM voltage?
dhanna6powerstroke is offline
post #3 of 18 Old 12-31-2012, 10:08 AM Thread Starter
Quoted: 241 Post(s)
Taking the cover off the top and using my meter. tested 47.6 not running, 48 while cranking. Perfect.
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #4 of 18 Old 12-31-2012, 10:13 AM
Mod Newbie
Quoted: 20 Post(s)
Next thing is gonna be to check HPO system. You have a scan tool where you can monitor ICP and IPR?
post #5 of 18 Old 12-31-2012, 10:58 AM
I think his dads irregular oil maintenance is gonna have a lot to do with this. 6.0's are very picky about oil condition.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #6 of 18 Old 12-31-2012, 11:00 AM
Mod Newbie
Quoted: 20 Post(s)
, but I doubt it's injectors. I'm gonna say with it being an 03, there is a very high possibility of HPOP failure.
post #7 of 18 Old 12-31-2012, 12:43 PM Thread Starter
Quoted: 241 Post(s)
If a hpop failure, why would it have cranked and run for a minute. Any way to check the hpop without a scan tool, like I said he's to stubborn and cheap to buy one. Was thinking about getting the obd2 adapter and get the torque app on my phone. If I have to guess I will a little sooner than I planned.
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #8 of 18 Old 12-31-2012, 12:54 PM
Mod Newbie
Quoted: 20 Post(s)
I'm not sure what all that Torque App will show. Try unplugging the ICP sensor and seeing if it will start. With it being an 03, it's kind of a PITA to get to since it's under the turbo. Should also check fuel pressure. If pressure is good and it doesn't start with ICP disconnected then it's either a HPO leak or IPR valve issue.
post #9 of 18 Old 12-31-2012, 12:55 PM
Mod Newbie
Quoted: 20 Post(s)
How many miles on the truck?
post #10 of 18 Old 12-31-2012, 01:25 PM Thread Starter
Quoted: 241 Post(s)
Neighborhood of 160000. The ipr valve was replaced about year and half ago. The valve is the one under the turbo, coming out of the hpop housing. or is that just the sensor? that and the pigtail was replaced then,I did it, it had the surging problem then. I that the valve or just the sensor. That was always a little un clear to me.
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
