Hello. I have a 2006 6.0 F350. When driving slow and steady the engine sounds normal. When accelerating and making the RPM's get 20/2100 and up there is a sound present and cuts in an out. It is sort of a air sound, or like a wet towel being drug accross glass. I am having a hard time explaining it.
A friend said it might be a vaccum leak or a clogged air intake. It will do it once in awhile if the cruise is set and I am going up a hill. I am also having the no heat at idle issue also. Maybe 2 related issues. I apologize for the weird description but you all seem pretty darn knowledgeable and probably know what I am talking about already.
The only vacuum related to diesels is under the dash for the ac dampers, and the 4x4 if you have esof. With that said, you shouldn't notice a difference with acceleration. Do you have a monitor, is your truck running ok, is your truck creating boost, do you have any smoke, do you have an egr?
Sent from my phone that somebody didn't help me get. |
Thanks. |
ESOF- Electronic Shift On the Fly
O yeah.... I forgot to add in... and don't hit on me for my mistake but I do not believe I am harming anything and am going to do a full coolant system flush this weekend.
I noticed that the coolant bottle we empty and I read all over last night about the no heat at idle causes and I liked the theory about the system being low on coolant would not create enough pressure and such at idle so I stopped and got a bottle of silicate free coolant which is right according to the 6.0 trouble section, and added it in. It does not meet so and so spec Ford Gold stuff but that is the coolant that contains silicates.... I couldn't tell what color was in the truck but the stuff I added was orange. I am going to stop by Napa and see if I can find a good flush additive to run the next few days before the actual flush. The truck took a gallon of the coolant and was sitting at the mark on the reservoir, drove around and the bottle was empty again so I need more. But the truck was making heat at idle and I parked and idled for about 10 minutes in a clean area in a parking lot and didn't see any leaking or such. The sound is still present under acceleration. I'm thinking a water pump issue.... Maybe this information helps.
Here... I am trying to make this as easy as possible for you guys trying to help. lol. This is a video I took this morning and you can clearly hear the sound and how inconsistent it is. I did pay attention to the boost gauge and it will go up to the 20 area while accelerating and such. When I said 8-10 earlier that was when cruise control was set at 60-70 mph. And the vents seem to work good and not only blow through the defroster. Although I am still reading a lot about low/no heat while sitting idle. Coolant drain and clean coming. I looked at all my local car places and the only coolant system flush I see is Prestone stuff and there is about 3 different kinds. Does it all do basically the same job or is there big differences?
6.0 Powerstroke acceleration noise - YouTube |
Does the noise happen only whole accelerating, does it do it with the cruise set on level ground?
Yes it only happens when accelerating. Slowing down, nothing.... truck in park and take engine rpms to 2500, nothing. I think that is because there is no load on it. When cruise control is set it will happen as I am going up a hill. It is mainly at the 2100 rpm and beyond mark, and really noticeable when getting up to speed. It will do it once in awhile riding around but again, it is as you speed up to pass someone etc...
