Died and will crank but not start...Please help
03 6.0 truck was running great n o issues slowede down to go across a speed bump, gave it gas to clear the bump as soon as the front tires cleared the bump the motor shut down like i turned the key off. never lost power but the motor just quit. will crank but will not even try to start. never acted up, just quit, not showing any codes!!!! please help could it be CPS?
Doubt it's the CPS. How many miles? Any way to monitor ICP and IPR values?
160,000 new HPOP and FICM last year. Before that all new injectors and head gaskets and ARP studs. EGR delete at same time. no way to monitor it its at the shop but they cant get to it till Wed so i figured I would reserch myself some. If it is something semple I nwill try it myself. Thanks for the help..
Well, pretty hard to diagnose one when you don't have access to it. You don't see the CPS go bad on a 6.0 very often. Not saying it can't be, just not likely. Best thing to do is let them run diagnosis on it and then fix it yourself.
