On the side the road! 9-1-1 - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-29-2012, 05:43 PM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
Tryck died after having no boost issue... Truck will not perform any starting procedures, pumps glow plugs blower etc. checked all fuses with multimeter and theyr all good key on and dash works but no click or cranking. Checked as many sensors and wires as i could and they all look fine any input would be amazing right now. Thanks a ton guys!
Sent from my iPhone using AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #2 of 8 Old 12-29-2012, 05:50 PM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
Sct tuner shows no strategy tune vehicle info or codes
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #3 of 8 Old 12-29-2012, 06:36 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Sounds like your PCM isn't connected. Check the harnesses and plugs on the driver side inner fender beside the battery tray.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #4 of 8 Old 12-29-2012, 06:56 PM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
Middle plug on the harness removed and it will crank but no start
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #5 of 8 Old 12-29-2012, 07:04 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Plug it back in then try again. Also check the crank and cam position sensors and pig tails. One other thing to try is unplugging the icp harness off of the icp sensor and try it again. Do you have a monitor?
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #6 of 8 Old 12-29-2012, 07:36 PM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
Sct tuner. But it isnt viewing any vehicle info, strategies, nothing at all
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #7 of 8 Old 12-29-2012, 07:37 PM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
Also, replaced icp, harness and ipr two days ago and wrapped the harness reL good with heat sheild wrap
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #8 of 8 Old 12-30-2012, 07:59 AM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
Theres a one wire sensor behind the oil filter ontop of the oil cooler, that thing looks drenched in oil, but the harness is fine, does that sensor have anything to do with the engine starting? With the middle pcm connector out i can hear the normal starting sounds like fuel pump but it will not start at all. Thanks again for all your help!
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
