Bad thermostat or normal??
I finally have been-able to put on some miles since getting a monitor. The outside temps have been in the teens and twenties. I am only seeing ECT temps of around 177-178*...........Is my thermostat bad, or is my cooling system good??
If it makes any difference, my deltas have been around 6-9* |
This ^^^
Sent from my phone that somebody didn't help me get. |
so should i worry when i'm seeing 160-175, normally in the 160's with ambient temps up to 60?
That's extremely low. Sounds like yours is stuck completely open. Need to replace it. Will probably be surprised how much better it runs.
truck seems to run pretty well now but i do plan on digging into the engine for studs and some other things and probably will do the thermostat then.
So does it make sense that i am getting good HOT heat from the heater, even if it is stuck open? The dash gauge shows normal, I have great heat, but according to the Livewire, I'm running cool.
Still change it? |
when doing ur t stat upgrade to the blue spring mod too
You'll have heat even if the thermostat wasn't there at all. The problem is that you're engine and sensors aren't making it to normal operating temps which is hard on it.
