Confused PLEASE HELP - Ford Powerstroke Diesel Forum
Old 12-28-2012, 02:34 PM
Ok replaced alternator. Batteries and Alternator read 25V with truck running when using a multimeter, when i hook up a tester it says 12V at batteries and LOW VOLTAGE 11.4V on the charging system. FICM reads 95V with ignition on and truck running. Should i be concerned?
Old 12-28-2012, 02:50 PM
Illiana Chapter Director
I think you're reading the meter wrong.
Old 12-28-2012, 07:18 PM
No I'm not. I use multi meters for a living. It could be faulty but doubt it.
Old 12-28-2012, 07:22 PM
then yes you should be concerned as hell
Old 12-28-2012, 07:48 PM
You do know that you only have a 12 volt system right... It's two batteries in parallel.
Old 12-29-2012, 04:40 AM
Either you're reading it wrong or you have one battery hooked up wrong and made it a 24v system
