loud squeak after start up... - Ford Powerstroke Diesel Forum
Old 12-24-2012, 09:31 PM
once the truck is running then the oil pressure gauge jumps like normal then i get a loud squeak from under the hood as soon as the turbo begins the spool... is this a sign of VGT wear? sounds like when the solenoid functions the disc in the turbo is dragging or the fins on the VGT thing are dragging..??? any ideas??
Old 12-24-2012, 09:58 PM
Illiana Chapter Director
Can you get and post a video of it?
Old 12-25-2012, 11:08 AM
I have seen weak tensioners do that when letting off the throttle quicly. The belt will skipp for a few seconds instaed of rolling over one of the pulleys.
Old 12-25-2012, 06:00 PM
2006 f250 mystery squeak. - YouTube
Old 12-25-2012, 06:03 PM
posted.... i dont know how to put the actual vid on here but theres the link above.
Old 12-26-2012, 04:25 AM
Was it the noise when the vid pans over the banks intake? All I heard was a single squeek. I too have something but it is consistant. At idle it's present and you can notice it driving around at low speed if you listen hard enough. I think my water pump is on the way out, just haven't had time to pull the belt (which is pretty new and I checked all the pullies before installing) and check it again. So maybe pull the belt and give everything a glance?
