Eot & ect staying between 10-15
07 6.0 70000 miles ect & eot staying between 10-15 with no load just die Egr delete and new oil cooler new radiator new clutch fan new water pump any ideas????
That is where you want to be, 10-15 degrees. Maybe I'm misunderstanding.Just to throw it out there, unloaded and on the highway..i can see up to a 20 degree variance, been like that for about 2 years and everything has been good. Well not good, i think i have an injector on the way out. |
What are your readings cold? It could be a sensor reading off, the reading should be close cold. Are your ect at least 190 plus or minus a degree. If not it could be a stuck t-stat. We kind of need some readings operating temp and cold temp. You could have the wrong balance of coolant to water ratio.
Same here... At 65 mph on the highway, my deltas are generally bewteen 9-11 degrees. It's been like that since changing out oil cooler and coolant two years ago. I've accepted it as just the way it is.
Yes at 65 it's between 9-11 I don't care as long as its not hurting anything but win u turn programmer up to extreme it blows coolant win u turn it off and put it on stock and pull 10000 camper it blows coolant and over heats I'm thinking hgs bc I've replace everything!!!
What programmer are you using? |
Bully dog gt tuner
