no turbo/boost pressure - Ford Powerstroke Diesel Forum
Old 12-19-2012, 08:47 AM
I sprayed engine cleaner/degreaser on my engine to clean it last night...i didnt get real close to anything and used the fan kind of tip..this was at a buddies i then dorve a few miles home and started trying to figure out a overhead computer problem im having with not getting power to the thing...anyways
My question is do any of these plugs in the picture mainly the 2 black ones have anything to do with the turbo at all? I had unplugged the two, checking which wires had power etc with key on and off tying to diagnose hte overhead computer issue.
I just want to make sure my problem is directly related to my powerwashing fyi i did check the 1/4" hose from my map to mainfold is still on........ at lunch in a few minutes im going to pull it off and make sure its clear and nothing blocking on the inside.
no turbo/boost pressure-picture-097.jpg   no turbo/boost pressure-picture-099.jpg
Old 12-19-2012, 08:53 AM
Illiana Chapter Director
Those have nothing to do with your turbo, and most likely not causing the overhead console issue. I'll bet if you pull the console down and get to the display, you'll find at least on chip broken loose from the circuit board.
Old 12-19-2012, 09:24 AM
well i tooke that line off and blew through (compressed air) and also disconnected that clip that plugs right into the turbo quick blew both sides of that plugged everything back in and its good must of been little moisture in there or somewhere
The overhead computer was already sent out and repaired i was down in that area tracing the power wire to it...i get no power to my plug that the thing plugs into, but i get power to the wire coming right off the fuse theres a splice somewhere in the truck according to the diagram where it must be broke was trying to find it...still am its where the wire goes from light blue/pink to /red/yellow but anyways glad my turbos spooling up again
Old 12-19-2012, 09:28 AM
Well, now I have no idea. I don't have a wiring schematic even to help out.
Old 12-19-2012, 10:28 AM
lt blu/pink to red/yellow
no turbo/boost pressure-overhead.jpg
