HELP... WONT STAY RUNNING! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-17-2012, 11:06 AM Thread Starter
IVE GOT AN 03 F350 6.0 SHUT OFF ON START UP ABOUT A WEEK AGO. STARTED OUT INSTALLING A NEW FUEL PUMP ASSEMBLY. NO LUCK THE INSTALLED NEW ICP AND PIGTAIL, STILL NO LUCK. SO I PULLED VALVE COVERS AND PRESSURISED THE OIL RAILS DRIVERS SIDE WAS FINE. PASSANGER SIDE I COULD STILL HEAR AIR AFTER CLOSING IPR SO I REPLACED IPR THINKING THE THAT VALVE WASENT CLOSING ALL THE WAY STILL SAME ISSUE. WHEN I GOT MOTOR ALL PUT BACK TOGETHER I STARTED AND IT STAYED RUNNING FOR ABOUT 20 MIN AND THEN SHUT OF AND THE MORE HEAT THE MOTOR GOT IN IT THE SHORTER AMOUNT OF TIME IT WOULD STAY RUNNING NOW THE TRUCK WONT RUN FOR MORE THEN ABOUT 2MIN. ALSO PULLED BOTH STAND PIPES AND CHECKED BOTH ORINGS ON STAND PIPES
PLEASE HELP!!!
khall is offline
post #2 of 8 Old 12-17-2012, 02:32 PM
southend's Avatar
First, no need to type in all caps, makes it harder to read. Do you have a monitor.......Write Up: Monitoring the 6.0L PSD.
If not, it will save you alot of money in geuss work. Is the truck smoking, was it smoking prior to shuting down? Check for combustion gases in the fuel rail, remove the upper fuel filter, hfcm fuse, and ficm relay. Crank the truck over and see if you have combustion gasses in the housing. Have you checked the egr to see if it is stuck open? Are you running motorcraft filters with matching cap, and a good quality oil?
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 8 Old 12-17-2012, 02:52 PM Thread Starter
Sry about the all caps.
Yes I have ford Ids with vcm2. Truck is not smoking now or when problem first started. Checked for gasses this afternoon and pulled egr and put in a new spare that I had. Truck dose have new motor craft filters and fresh rotella
After posting this I also pulled oil pressure and installed manual guage to make sure that motor had low pressure guage went to 35psi
And while cranking on motor will only build around 360psi on icp pressure but get truck to run if u spray it but still only builds around 600psi and will only run for about 5 minutes before pressure drops and truck shuts off but you can slowly watch pressure drop within the 5 minutes and truck will only run if u spray it
Thanks
Sent from my iPhone using AutoGuide.com App
khall is offline
post #4 of 8 Old 12-17-2012, 02:59 PM
Eric@PTP's Avatar
Check the STC fitting and the dummy plug and stand pipes, more than likely one of those is you failure point.
1-888-516-4644
GO NAVY
Eric@PTP is offline
post #5 of 8 Old 12-17-2012, 03:14 PM
southend's Avatar
He has an 03', op you dont have the famed "stc" fittings that fail, but you do have stc fittings on the hpo hoses under both valve covers, and you have standpipes. No dummy plugs. As suggested, you have an oil leak somewhere, best to repeat the air test again. Could be the check ball in the hpop that popped out, hpo hoses, injector o rings, or standpipes. I'm guessing check ball at this point.
southend is offline
post #6 of 8 Old 12-17-2012, 03:22 PM
Eric@PTP's Avatar
Yep, I missed that it was an 03 sorry. But I agree there is a oil leak somewhere.
1-888-516-4644
GO NAVY
Eric@PTP is offline
post #7 of 8 Old 12-17-2012, 03:23 PM
Low pressure system should be greater than 40 psi so you have a low pressure leak somewhere which also be why your looseing hpoil pressure. LPOP not putting out enough oil flow to keep the HPOP resivoir full and allow gradual loss of HPoil pressure.
Check your LP regulator for damage/leak and the filter components for anything fubared.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #8 of 8 Old 12-17-2012, 05:22 PM Thread Starter
I checked the orings on the stand pipes and just went ahead And replaced them sence I had them out. And sence I've already air tested the rails would it be better to plug the rails and pressurize at the icp?? And I've heard of the branch tubes leaking but never seen or heard one leak what would you look for when checking the branch tubes?
Thanks
khall is offline
