What aftermarket turbo for 06 6.0
Had my truck at dealership for 3 days and they cannot figiure out why I keep getting low boost code. I had the turbo cleaned last year and it has been good until lately. The mechanic says the vanes are free, but can't tell if it is the turbo or solenoid that controls the vanes. No air leaks or other issues that he can find.
So what aftermarket turbo do I need and else has to be done to make it work? Ballpark would help also |
If what you wrote above is what you heard, then find another mechanic ASAP!
Page 35 of the 03 bible. VGT is electrically actuated and hydraulic controlled. •The VGT control valve is commanded by the PCM, based on engine speed and load. The magnetic field generated by this signal moves a shaft in the control valve. This movement meters engine oil through the valve to either side of the piston. This design feature reacts quickly to changes in demand based on driving conditions. When one side of the piston is pressurized, the opposite side is vented. • Depending on which side of the piston is pressurized, the vanes either open or close. A cam follower at the end of the valve assembly provides feedback to the valve allowing it to reach a neutral position during times the vanes are not commanded to move. You can read more once you get the 6.0 bible. |
no chit
your OEM turbo is a good choice for a stock truck |
Sorry that I said that wrong about it being a solenoid, He checked the oil pressure to see if actuator would have enough hydraulic pressure.
If your lookin for a great budget turbo that will put perform a powermax and work perfectly with stock and performance tunes you simply cannot beat a MTW Stage 1 for $775.
you would think any decent 6.0 tech is gonna have a few spare VGTs around to have as testers.
Apparently some areas have better dealerships than others, maybe I'm just in a small market area, I wish I knew.
Did a little reading about the Stage 1 after your post and seems like good option. Thanks for the good info. |
