leaking coolant after egr delete - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-12-2012, 05:18 AM Thread Starter
dkapp0802's Avatar
so i posted this on another forum but nobody really seemed to know so im posting it on this one.
i did a egr delete (welded it shut) and put it back in to make it look stock. i got it all put back together and started it up and i noticed that there was coolant running out the back of the right bank. i have no idea where from i trired looking but cant realy see. all i could see what to just below the right head. i tried tightening the rubber hose on the egr cooler and tried tightening the donut side. still nothing. i checked all of the freeze plugs and the ones that i see look fine and the onse i felt, felt fine
a uncle of mine is thinking maybe i bent one of those oh so strong stock head studs. me personally was thinking well then i would be getting coolant in my oil. but i have nothing. so im entirely lost here.
have any of you had this problem at all?
6.0 powerstroke tan with black trim, egr delete. 2" leveling kit, white interior led upgrade, stc fitting upgrade
if it smoking, you aint strokin
dkapp0802 is offline
post #2 of 4 Old 12-12-2012, 05:43 AM
Term3's Avatar
Coolant leaking from the egr cooler into the engine valley can run along the head/block line and look like the head is leaking. I'd look again at your coolant hose to the EGR cooler and at the egr coolant outlet O-ring. You did weld both ends of the cooler shut didn't you?
Sent from my iPhone using AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 4 Old 12-12-2012, 06:19 AM
ya dont weld just one end shut
2004.5 Mods: CTS, Lots Of Gauges, 7 inch Stack, ARP Studs, Tuned by Eric, SAP Diesel Full Fuel System, WEP Ported Intake Manifold, Mechman Alt, BPD 6 Phase Ficm, BPD Oil Cooler, BPD Oil Bypass, Warren 350cc conventionals, SAP Diesel/Warren Diesel Twin Pump Kit, SAP Diesel Triple Turbos and SAP Diesel Trans in Progress.
g2shuck is offline
post #4 of 4 Old 12-12-2012, 06:52 AM Thread Starter
dkapp0802's Avatar
yeap both ends are welded shut. i tried tightening those rubber hoses but i was thinking about just putting like a hose clamp on there. i was planning on doing studs anyways because im putting in some 155's and then gonna get some custom tunes
