My sway bar end link was rubbing against the tie rod adjustment bolts from the alignment shop a few years ago. Now it is almost cut in half and I am going to replace it. Since my lift is around 4"-6" I am puzzled that a stock end link is being used. It doesnt look like extended brackets are used to hook the sway bar up to the frame. The sway bar link appears to be leaning forward quite a bit and was just curious if this is normal? If it is I am going to put a stock one back on. If its not, I'll get one that's a bit longer.
Thanks,
Guy
Sent from my iPhone using AutoGuide.com App
