glow plug are they easy to do
05 f250 i need to replace glow plug what do i need to know
Check out this thread Glow Plug Removal
The glow plugs themselves are fairly easy just unscrew them with a deep socket 6-point
Getting the wireing off without breaking the clips is the challenge. 50/50 you will break one,Ford recomends just changeing the harness. There is a method used where you use a lenth of 18 ga. wire wrapped in the space between the clip and the plug and pulling with smooth steady pressure and a rocking motion. I have an old door panel clip remover that works pretty well. Again use steady pressure and a rocking motion. Good luck. |
get the harness connector to rotate in the rocker box hole first. If the o-ring is stuck this will free it up. If you can't get it to move then stop and get a harness before you go any further
HAHAHA read my wriite up on the glow plug harness removal. Its the real world write up lol worst job ive ever done and completed to be honest.
Just did the number 6 plug on my 05 today. The hardest part was the air filter. The job took less then hour and a beer with very little issue. Make sure that you have something ready to help remove the harness. I made a tool and that took the most time just trying to get it to fit.
Trev |
I had to do the passenger side on mine; I found the hardest part to be removing hte inner wheel well.
I purchased a new harness along with the glow plugs ... didn't even bother with trying to "not break the clips" ont he original. |
