Temp guage fluctuating???? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-09-2012, 02:36 AM Thread Starter
07 6.0 69000 miles Egr delete,new oil cooler, new fan clutch, new thermostat, radiator flush!!! This truck getting on my last nerve everything u turn around something else pops up!! Pulling my camper truck will go up to 230 plus with the heater on it will do it sometimes just not as bad u drive it normal it's fine tonight comming home from work 5hr drive it was fluctuating from 180 - 216 dun it a bunch this morning after bout 3 hours it finally leveled out to 186 - 190 degrees eot and ect stays less than degrees apart!!! Would the water pump or temp senser making it over hear and not communicating with the clutch fan!! I have all this questions but dont no the answer any input would be great thanks!!
Speedfreak is offline
post #2 of 2 Old 12-11-2012, 02:49 AM
Int.Tech04's Avatar
if you removed the EGR valve, it will cause the fan to not operate properly (or so ive been told). best thing to do is use a programmer to turn off the EGR, or leave the valve in and plugged up. on the 05 and up, you had to do this, or risk overheating.
-Tyler- -Navistar Technician-
2004 F250 CCSB FX4 6.0 - XDP EGR delete, BPD Oil Cooler Relocation, SCT Livewire TS, 315/75/16 Falken Wildpeak A/T's, Rough Country 4in, stock DP with 4in straight pipe.
Int.Tech04 is offline
