Oil leak running down back of heads????
07 6.0 have a oil leak on back side of motor running down both heads onto starter and Trany lines more or less between block and head it looks like!! I just did the Egr delete and new oil cooler all new seals and intake gaskets what can leak oil on back side of motor I'm bout to do hgs and studs so win I do this what do I need to look for hpop fitting I'm guessing!!!
STC fitting, we sell those with every headgasket set we sell. Let me know if you need parts
If it was the STC fitting leaking that bad I think you would be having more issues then just a leak! Check your IPR could be cracked and leaking.
If it started right after the oil cooler install look down on the valley and see if it is leaking around the oil cooler area.
Sent from my iPhone using AutoGuide.com App |
