How would you feel?
Hey hows it going, my name is Steve I am a new member to this forum and hope im putting this in the correct spot.
I have just bought a 2006 1 ton 6.0L with a 6 speed manual transmission and 200,000km the truck is completely stock besides an 8 Inch lift and 35" tires and i absolutely love this truck, I have just received from the local dealership a list of all the work done to this truck while it was on warranty. the FICM Module has been replaced, as have the High pressure fuel pump twice. only 2 injectors have been changed since 2006 cracked turbo rings, EGR and a few other small things and many reports of lack of power. the last work done to this truck was in 2010 on warranty and the warranty has just ended within the last 4 months. does this sound like a truck that will be nothing but problems for me? or should i take the report as a warning. (it goes into a performance diesel shop for EGR Delete, Chip and ARP Headstuds on January 7th) I have also been smelling burnt coolant as of late, not frequently but maybe once every 2 weeks after driving on the highway etc.. also smokes alot on startup but when at operating temperature never. Thank you for your responses i am very new to diesels and this forum and am looking for somebody elses opinion on the matter! Last edited by lrgnugs; 12-05-2012 at 08:18 AM. Reason: forgot to add something |
Is it throwing any codes? Puking? Have you checked your FICM voltage? You already have it scheduled for studs and EGR delete, the only other thing I would add is possible an oil cooler at the same time. Check the STC fitting, stand pipes, etc. while he has all that apart.
Do you have any means of monitoring this engine, like a insight CTS/CS or a scan gauge? This is a necessity on these engines. You are getting the big issues out of the way and that should be a great start to making this a solid truck for you. There is a lot of good information on here. Check out the below link that one of the members here did. Great for anyone who is new to diesels. Things to consider about owning a 6.0L Good luck |
Thank you for the reply I will get those things you mentioned checked for sure also besides having a sct chip should I need the scan gauge still to monitor certain things ?
I read that write up boatloads of information. I don't know how to check the ficm voltage but ill search it up its not throwing any codes and is clean in and around the degas bottle This truck is my baby I work oilfield and every time I fly home it's in the shop getting some new things I just want to shut my dodge owner buddy up I think this 6 liter is awesome the sound and body style of my truck is so sweet thanks for the help ill get on this stuff right away! |
Here is a link to a video that shows you how to check the FICM voltage. There are SCT devices out there that can be used as monitors also, the livewire ones I believe. I do not have an SCT. I have a CTS to monitor everything. It just depends on what you want. Look into the livewire setups and see if that is what you want.
http://www.ford-trucks.com/forums/10...val-video.html |
Best guess on the burnt coolant is a ruptured EGR cooler, which may have been caused by a clogged oil cooler.
Any idea what your coolant temps and oil temps are? |
The smoke on start up may be injector stiction, which can be cured with rev x or archoil.
Just an UPDATE:
I've purchased and installed ARP Headstuds, SCT Livewire TS, EGR Delete and a Scangauge II and have on order a blue spring upgrade kit. one of my really good friends is a ford diesel tech at a ford dealership, he took my truck for a test drive with the computer hooked up to it and found 2 bad injectors and my turbo was sticking/overboosting replaced the injectors this morning and had my turbo cleaned and i believe he called it a unison ring replaced. truck is running like a million bucks, thank you all for your input! |
Glad to hear that you got things sorted out!
Sent from my PC36100 using AutoGuide App |
Nice tires, I have a smaller set for mine too. They are expensive though!
