Help me diagnose this vibration
2004 6.0 f250 stock with exception of tuning and 5" exhaust.
I have a vibration in the floor on both the driver and passenger side. Vibration only happens at around 1500-1750 rpm in every gear. 1, 2, 3, 4, 5, 5L. Even does it in neutral and park when I rev it up, but it is not as bad as when I am in drive. I'm really stumped what this is, anyone have any ideas? Sent from my Autoguide iPhone app |
Anyone?
Exhaust rubbing the cab or frame?
Sent from my phone that somebody didn't help me get. |
I can't find a spot where it is rubbing. I had checked that before and it was rubbing the shackle bolt, but have since then fixed it.
If you wouldn't have said floorboard vibration, i'd have said bad injector.
I heard spool valves can make it vibrate about this range of RPMs so not sure if its my injectors or what type of vibrations injectors will make.
I also heard something about it maybe being exhaust/turbo drone. Wondering if anyone has experience with this. |
I had an injector take a hike, idled like crap, and shuddered/vibration at 60-65mph, but would clear up when getting on the throttle. There is a tsb for tutbo droan, may have only been 03', iirc. Check your tutbo mounting bolts.
This is the TSB:
http://www.thedieselstop.com/faq/949...les/041804.pdf Anyone have any experience with this TSB? It would kinda suck to buy $60 pedastal just to find out that's not the problem. |
You may want to check your motor mounts and transmission mount for busted rubbers.
I had a similar issue after replacing the hpop. I found the number two cylinder harness for injector was not snapped all the way on. Causing a dead cylinder at times, which then was causing a vibration in about the same rpm area you are describing. It would go away under wot.
Sent from my DROIDX using AutoGuide.Com Free App |
